Discussion topic: Add Scottish channels
This message was authored by: Tea4
Message posted on 31 Dec 2025 08:00 PM
How do I add Scottish channels like stv and bbc two scotland
Find out more
Message posted on 31 Dec 2025 08:30 PM
Re: Add Scottish channels
hi @Tea4
Assuming you are not in Scotland then you probably will find BBC Scotland on channel 964
STV is not available via the EPG & you would need to add it manually
Settings - Manual Tuning
You can find the parameters on this link:
https://www.lyngsat.com/Astra-2E-2F-2G.html
Note you cannot get any epg for manually added channels and can only watch live
You may be able to watch via STV player if you have set up credentials
