Discussion topic: voice commands
This message was authored by: ChrisatLymm
voice commands
Since installing multiscreen, I have been unable to use the blue button and can't thus use voice commands. It works on the minibox, but not on my main box. Previously I have had no difficulty with this
Re: voice commands
hi @ChrisatLymm
Please can you let us know what happens/any messages etc.
Re: voice commands
@ChrisatLymm
Your duplicate thread has been removed as you've already had a response on this one.
Re: voice commands
@ChrisatLymm Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for ChrisatLymm
Re: voice commands
yes: it worked!
