Discussion topic: Multiroom keeps freezing
This message was authored by: Ralph25
The tele upstairs repeated freezes for a few seconds every 5 minutes or so. The hub also loses connection to the q box. Everything is connected properly and we've had this set up for years. The main box works fine. Is the multiroom hub just losing signal due to age?
Re: Multiroom keeps freezing
Hi @Ralph25
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
