Discussion topic: the sky button wont switch tv on
This message was authored by: double
my sky mini box has lost the ability to  turn the tv on its a panasonic tv
Re: the sky button wont switch tv on
Check the CEC settings as the mini sends an 'on' signal via this.  Check both the mini and TV to ensure HDMI settings are correct.
Avatar for double
what are cec?
This message was authored by: Ecosse
Take a look here.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Avatar for double
unfortunately  my tv a panasonic
This message was authored by: bob1234
@doubleEither post the exact model, some are different, or look in the manual.
CEC is also known as "HDMI control"
Panasonics support CEC. They just all use different names for it, annoyingly.
do you want it to come on when you swtich the mini on (quick press) or when you hold fhe power button down for a few seconds?
Avatar for double
tv model txl37e3b both hdmi on same setting
