6
This discussion topic has been answered Discussion topic: sky uhd quality on my LG TV is poor
This message was authored by: NigelMas1
Hi, I have upgraded to UHD. When I play other HDR (in TV) sources the TV recognises it and displays HLG HDR and display an outstanding picture (ie BBC iPlayer uhd test loop). When I play the uhd main event channel and watch the ashes for instance or download a UHD programme the TV does not pick it up in the same way. I would also argue that whilst the LG does say it is picking up 2160 resolution it looks nowhere near as good/bright  as other UHD sources. I have ensured thr TV HDMI  is switched to IOS displaying ultra Deep colour and thy box is set to UHD 10 but. Any support would be appreciated. I have also tried searching prior posts...
This message was authored by: SecretBanker Answer
Re: sky uhd quality on my LG TV is poor
As above B0 is non HDR - hence why you cannot get HDR from your Sky Box. You will need to swap it our for a V2 or V3 box, for which Sky will probably charge you.
Panasonic HZ1000 | Sky Q 2TB | Denon X3700H | Panasonic UB9000 | Sony PS4 | Cambridge Audio CXN2 |Arcam SA20 | B&W /REL 5.4.1 | Harmony Ultimate One | | Sky VIP Diamond |
What model is the TV? Some of them can't get bright enough to display HLG properly (the format used by Sky for HDR) and this makes the picture look quite dark.
Avatar for NigelMas1
The model is C9 PLA and can display a good bright HLG HDR picture as demonstrated via other sources I.e bbc demo loop
@NigelMas1
What is the hardware version of your SKY Q box. If it is 32B0xxxx then it is UHD but not HDR
If it is 32B1xxx or 32B2xxx then it is HDR. If your tv is not recognising it as HDR  then you might need to check  all the settings for the HDMI.
I am afraid I don't know which ones other than the Deep colour
Hi, interesting my box is 32B063. Any ideas if this version of their box carries HLG? 😊 Thanks
Ok... well at least I now know... thanks so much for your help...much appreciated
