Discussion topic: Sky Cinema Live view not working @ 28-7-2023
This message was authored by: brian+ds
Is anyone getting poor display/no
display across the sky cinema channels only but all other channels work since Saturday 29th July 2023?
Cinema channels overlap and screen shows as though it's been damaged
All lead connections are tight, recording and downloading works on Sky , just the live view isn't working
Re: Sky Cinema Live view not working @ 28-7-2023
@brian+ds  What message do you get on live channels?
Avatar for brian+ds
No message just a scrambled screen -
seems to be any Sky cinema program before 8pm as they work now, so I'll need to check in the morning to see if it's the same problem before 8pm
@brian+ds  Do you mean the image is pixellated?
Avatar for brian+ds
Yes it is
Avatar for brian+ds
Yes it is pixelated
Avatar for brian+ds
No message and it's still pixelating even after 8pm yesterday:((
