Discussion topic: sky tv
Message posted on 01 Aug 2024 04:12 PM
sky tv
my sky tv has been taking its time to change channels up to 2mins i get blank screens I go to menu and no apps are visable this has been going on for approx 1 month and now the box will not switch on remote or manually
Message posted on 01 Aug 2024 04:16 PM
Re: sky tv
Hi @michaelpar3
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
