This discussion topic has been answered Discussion topic: sky q
Message posted on 16 Dec 2025 04:50 PM
i hve sky q and had trouble in the past with network connection, an engineer came and reconnected it and its been great for months/years a couple of months ago it lost connection again and i have been unable to sort it out, can't explain to anyone at sky because i keep being sent down all the troubleshooting channels, ive gone on the chat bot thing to get someone from sky to call me because i'm still having to pay for a service im not getting?!?!
Message posted on 17 Dec 2025 11:43 AM
Hi @customer64
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home.
Regarding your issue
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Hi @customer64
To contact Sky
