Discussion topic: sky q not working
Message posted on 10 Jul 2025 08:08 PM
sky q not working
no sky tv and no access to sky menu or settings
Message posted on 10 Jul 2025 09:44 PM
Re: sky q not working
Hi @mmmmmmm,
Have you tried rebooting your Q box?
Message posted on 10 Jul 2025 10:28 PM
yes tried that still nothing, going try to order a new skyq box
Message posted on 10 Jul 2025 10:41 PM
Hi @mmmmmmm,
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 11 Jul 2025 11:49 AM
I received a new skybox two weeks ago...I have rang in twice and not got the problem sorted...it is saying on the screen that I need to pair my viewing card...I've followed the instructions on line to no avail...i spoke to a representative that tried to pair the viewing card from her end...asked to wait for 24 hours to see if that worked...it didn't...I didn't want to book an engineer and be waiting in....the first guy that I spoke to was totally hopeless...but the lady I spoke to was very helpful but unfortunately it still didn't work....I'm very frustrated.
