Discussion topic: sky q mini box
Message posted on 06 May 2025 10:52 AM
sky q mini box
my sky q mini box is saying its not connected to the activation server. Ive turned everything on and off to boost it but nothings working.
Message posted on 06 May 2025 11:11 AM
Re: sky q mini box
Hi @curryhot
Complete the following.
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
