2
This discussion topic has been answered Discussion topic: TV code so sky Q mini box remote works my TV.
This message was authored by: Owler1867
My tv is a cello is a C4324WSF Smart tv.
Can anyone provide a code for this?  When I try and set it up,  the search doesn't recognize my Tv.
This message was authored by: stereohaven Answer
Re: TV code so sky Q mini box remote works my TV.
Is it using Google TV or WebOS as it's operating system?
Some people have reported that if it is the WebOS version you can use an LG code.
Otherwise, try the "Other" option, others have reported one of those working.
Avatar for Owler1867
Thank you so much. Tried the LG route and it worked straight away. Very much appreciated.
