6
This discussion topic has been answered Discussion topic: sky q mini and tp link
This message was authored by: steveblue8
Hello
i need some help i have my dining room sky q mini connected to a tp link switch
also my  pc,
i am occasionally getting picture dropouts every now and then?
i have tried wi fi to the mini  but is far worse,
i am doing something wrong?
any help offered will be appreciated
Steve
This message was authored by: MightyQuinn Answer
Re: sky q mini and tp link
Hi @steveblue8   Unfortunately there is nothing wrong. If both Main box and Mini box (via unmanaged switch) are connected to the Router using Ethernet then that is right. So try swapping Ethernet cables and eliminate a problem with the switch.
Hi @steveblue8   Is your Main Sky Q box also connected by Ethernet on the same LAN.
Avatar for steveblue8
Level 3 icon
Yes its connected by ethernet via the tp link switch
Level 3 icon
Sorry my main q box is connected by ethernet to the sky hub
then i had one ethernet connected from the sky hub to my pc
the mini box in the same room was wireless and keptb dropping connection
so i bought a tp switch the main q box is not on the same ethernet cable
its seperate
i hope that makes sense ?
This message was authored by: Me134
its seperate
So the Q box connects via ethernet to the router and the router connects to the switch which then feeds the mini box and your PC?
Have you disabled wifi on the main box and the mini? Is the switch managed or unmanaged?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Level 3 icon
yes that is correct i have wi fi off on both boxes the switch is unmanaged
