Discussion topic: sky q box issues
Message posted on 24 Sep 2024 04:58 PM
							sky q box issues
Hi i seem to be one of many that has pixelating/picture distorting while using apps built into sky q box
the same apps work fine on tv inbuilt apps so this as another user posted this has got to be a sky tech issue on phone earlier today got cut off yesterday when through all the reboots prior to call refreshed apps on box.
The customer handler did try to help thought issue had rectified itself but sadly it came back later
did read a post from a sky employee that they are aware of the issue & are working on it that was posted on the 4th Sept.
Is there anyone who had same issue found a cure.
I feel i will need to ask for a reduction in my charges as this seems sky cannot solve the issue
Message posted on 25 Sep 2024 10:42 AM
							Re: sky q box issues
@humpty1947 wrote:I feel i will need to ask for a reduction in my charges as this seems sky cannot solve the issue
I suspect they'll politely decline that request. Especially as you have access via your native TV apps.
Always use a native app if you can - they won't suffer the enforced framerate of the Sky ones.
Message posted on 25 Sep 2024 11:51 AM
I replacement box has fixed it for me and some others but hasn't worked for everyone. I would like to do a survey on hardware version and pixelation but there not allowed on these forums 😞.
There does seem to be some correlation with main boxes that have an external PSU (as is my replacement) not suffering with this issue; I havn't seen a post that contradicts this yet....
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
