5
This discussion topic has been answered Discussion topic: How do you get Sky Q remote to control LG soundbar
This message was authored by: PDWQ
Hi
How do you get Sky Q remote to control an LG soundbar. The soundbar is connected to the TV via optical. Need to know the codes to reset remote and set up for the TV and soundbar
Re: How do you get Sky Q remote to control LG soundbar
@PDWQ wrote:
Hi yes I know optical can't do this that is why I have asked for the codes. When you initially set up the remote it asks you for tv model and then soundbar model so you can control them direct from the remote. I want to get back to the initial setup and start again.
Hi @PDWQ
Best to completely reset your Bluetooth remote.
After pairing to TV you have the option to pair to a Soundbar/Amp for Volume and mute (that's instead of TV volume).
On/Off and input select is always reserved for paired TV.
Codes are not used for Q Bluetooth remote.  (Only brand and model for TV and/or Amp/Soundbar)
The remote is primarily to control the TV.  The best way is to connect the soundbar to the TV via HDMI and let CEC control the volume via the TV.  (Optical cannot do this)
There may be a code that controls the LG soundbar - see if your device is listed, or try the various LG codes to see if one works.
Avatar for PDWQ
Hi @PDWQ
Avatar for PDWQ
Thank you oldfella
that has sorted it 👍🏻
This message was authored by: DazWilliams
I have Sky Q and struggled to learn to my YSP 2200 yahama soundbar.
in the end it is: press buttons 1 & 3 and the red remote LED flashed twice then enter: ? 3 3 5 5
it should flash twice and it worked for me.
