Discussion topic: sky q and discovery plus
This message was authored by: Suzyjanejane
I am trying to add discovery plus to my sky q package, but cannot do it
Re: sky q and discovery plus
@Suzyjanejane try using the link below you need to follow the instructions precisely
https://www.sky.com/help/articles/discovery-plus
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Suzyjanejane
thank you so much for replying,  for some strange reason, there is no discovery plus on  my sky!  I had tried that
@Suzyjanejane if you dont have the app in the apps section you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
