Discussion topic: Hard disk drive problem
Message posted on 02 May 2023 08:24 PM
Message posted on 02 May 2023 08:33 PM
Re: Hard disk drive problem
@janley wrote:
I can not get any information on programs and no recording available.
@janley Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 02 May 2023 08:38 PM
This is what I missed out I have not got Sky q I only have the old sky box.
Message posted on 02 May 2023 09:15 PM
*I think this needs moved to the sky + forum then.
Additionally, you may need to access the engineers menu to 'hard reset' those boxes - from memory years ago.
Settings - press 001 and then you can access that menu to scroll - can't remember off my head - to an area within there to format your hard drive to have it as if new again.
This will remove all recorded programs and will bring your box back to a clean slate.
Sky Glass 65”
Sky Fibre 500 WiFi Max
Been a sky customer through the ages from before HD boxes were a thing! When sky was a box you had to wind up to work
Message posted on 02 May 2023 10:09 PM
@Kevin-7248 @janley @Laing1 hi when your in the menu you need to scroll o system reset and your get a notice that your lose recordings ect before you reset and it will want you to confirm your wishing to continue
Message posted on 02 May 2023 10:36 PM - last edited: 02 May 2023 10:37 PM
@Kevin-7248your welcome hope it fixes your issue 🙂 😄
Message posted on 03 May 2023 08:37 AM
@loverboi Oh it ain't for me, I just forgot your additional process of accessing the engineer menu's final hard reset guidance to it.
I've sky glass 😋 just wanted to help out @janley
Sky Glass 65”
Message posted on 05 May 2023 07:16 PM
Thank you all sorted now.
Message posted on 05 May 2023 08:45 PM
@Kevin-7248no worries hope your all enjoying the warm weather 😉 😄
