Discussion topic: sky max
This message was authored by: LaraCribb
sky max
Why am I unable to download shows playing on sky max as an entertainment customer?
Re: sky max
Are you trying to download HD without a HD sub?
Re: sky max
First check that you are not trying to Download or view HD or UHD content without the Q HD or UHD Subscription pack.
The Sky Q Sports pack and BT Sport if you subscribe through Sky are in HD as Standard.
Sky Cinema if you subscribe is also in HD.
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Avatar for LaraCribb
Re: sky max
it won't let me download in SD or HD but I can watch the sky max channel no problem
Re: sky max
Did you change the setting in preferences and not just in Formats @LaraCribb
Re: sky max
Yes changed my default settings and still didn't work
Re: sky max
Hi @LaraCribb
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147?
This message was authored by: Addie15
Re: sky max
Hi there! Thank you for escalating this. We have sent an invite to LaraCribb.
Re: sky max
Update-We are closing this invite now due to no response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
This message was authored by: Owen1511
Re: sky max
Is sky max hd free to upgrade
Re: sky max
@Owen1511 you need to subscribe to the Sky HD pack to watch Sky Max in HD which is around £9.00 per month roughly
Re: sky max
Thank you this helps
