Discussion topic: sky customer id
This message was authored by: awilson714
Message posted on 22 Apr 2026 04:45 PM
sky customer id
hi
where do i find my custonmer ID, The partner id which will be a 12 digit numbers starting with SKY-GB-wbdiscovery .
I only have a customer id which it not the same as its numbers only
regards
alex
Find out more
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Please note: I am just a sky customer not a employee - posts from sky employees (aka community team) are clearly marked as suchmy setup: Samsung 5 series 32inc tv | sky +hd box | variety, SKY & TNT sports,sky cinema | Netflix and prime video Please note: I only provide help on the main forums and not via PM ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ if this post has helped please give it a like ~ if this post has solved your question/query please mark it as the answer in order to help others
Message posted on 22 Apr 2026 04:50 PM
Re: sky customer id
@awilson714 the partner id can be obtained by calling sky
If you have issues signing up to either Disney+ or HBO MAX please select the relevant sky help article below to see if it helps resolve your issue
Disney+
HBO MAX
