Discussion topic: sky box keeps cutting out
Message posted on 01 Nov 2024 06:20 PM
my sky box keeps cutting out rebooting it 3 or 4 times a day need an engineer out
Message posted on 01 Nov 2024 06:46 PM
Re: sky box keeps cutting out
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
