Discussion topic: Very slow internet on sky q box
This message was authored by: Mike1712
I moved my broadband to someone other than sky and now my sky q box is almost unusablely slow with the internet. Can barely download at episode of something to watch.
I have tried the advice I've seen with regards to resetting the box and the router. I've also had an engineer out and gotten a new box. The internet is faultless with my other devices and works very quickly. It is only with the sky q boxes, including the new one that this issue exists.
Re: Very slow internet on sky q box
Hi @Mike1712
No idea what you have done when you say resetting the devices.
Did You complete the following?
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
If you still have issues do you have the possibility to connect your main Q box by Ethernet to your router?
Avatar for Mike1712
Yeah that's all been tried before and after changing my sky q box. I did the reset process in the exact order you described. An ethernet connection is impractical with the location of my router and sky box.
This problem is new to me as everything worked fine until the day before yesterday.
Assume you have checked that the Q box is on the latest Software @Mike1712
Avatar for Mike1712
Yeah I've double checked that as well.
It just seems like the box won't let me get over 30 Mbps
