Discussion topic: Remote broken
This message was authored by: Paul+G+D
Remote broken
My remote broken. How can I watch TV without
Re: Remote broken
@Paul+G+D
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (there is the possibility this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
In the meantime it may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
Avatar for Paul+G+D
Re: Remote broken
I have sky remotes for other TV in house will that work?
Re: Remote broken
Yes if they are Sky Q remotes @Paul+G+D
You can pair them to any Q box.
With the Q box on with green led just reset the Bluetooth remote.
