Discussion topic: sky 2tb 3rd mini box
This message was authored by: wolfy379
hi we have a sky tb2 box  multi room , and 2 mimi boxes in 2 bedrooms + the main box in the loung,e  i want to get a 3rd sky mini box for another  bedroom room , so  we can use sky to watch  terrestrial tv  or other apps through sky mimi box and not a tv aerial as poor reception
Thankyou
Re: sky 2tb 3rd mini box
Thankyou
hi @wolfy379
You can't use a 3rd mini box at the same time for any Satellite channels or recordings - although I believe it is possible to use 3 at the same time if one is only being used for a streaming app such as Netflix or Disney + and in use before the 3rd one is used.
A Mini box has no such functionality by itself: the restriction which @nigea99 indicates still applies.
The five PSB channels are likely to have apps on any current smart television set, or on multiple other streaming devices.
