1
This discussion topic has been answered Discussion topic: q box not working
This message was authored by: alanyx
q box not working
my sky q box has stoped working.. it wont respond to the remote at all
This message was authored by: nigea99 Answer
Re: q box not working
hi @alanyx
May I suggest you try a reset of your remote (after ensuring it has fresh batteries)
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
hi @alanyx
