1
This discussion topic has been answered Discussion topic: Sky q satesatellite cable damaged
This message was authored by: FoxyM
My sky q satellite cable has been cut and needs to be rewired. How do I book an engineer visit?
This message was authored by: nigea99 Answer
Re: Sky q satesatellite cable damaged
hi @FoxyM
I believe these are the current methods for contacting Sky. Depending on your reason for making contact some methods are more appropriate than others …
call Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
online help via this link
https://www.sky.com/help
At the end of the help it MAY provide a phone number if it's appropriate.
 Sky Assistant is now available at the top of sky.com/help (or as a chat bubble bottom right if used before) for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
BTW It is possible that SKY may charge for this but I think often they don't
hi @FoxyM
