Discussion topic: programme unavailable
This message was authored by: Veronica62
most programmes i have been watching are now coming up programme unavailable- check your subscription entitles you to view on this box -   i have not made any changes and on the main sky box all is fine
Re: programme unavailable
Hi @Veronica62
Try reconnecting your mini box.
Reboot the mini as above.
