Discussion topic: problems deleting a recording from the viewing screen
Message posted on 07 Nov 2025 11:27 AM
Sometimes I start watching a programme and then decide I don't want it. At the moment, the only way I can delete it is by fast forwarding to the very end and then deleting in the usual way. Is there any quick way of deleting it without doing this?
Message posted on 07 Nov 2025 11:35 AM
Re: problems deleting a recording from the viewing screen
Hi @badger10
To delete a recording that is currently playing you need to select the Back up button (left of Home button) twice to exit the recording. You can then then delete it.
This needs to be done in Recordings - Most recent.
You cannot delete recordings if watching ftom the Recordings - Continue section.
Message posted on 07 Nov 2025 11:50 AM
Thank you - I'll try that. Does it work when youre playing back a recording too?
