Discussion topic: Sky Q box keep turning itself off.
Message posted on 07 Nov 2025 10:40 AM
Message posted on 07 Nov 2025 11:12 AM
Re: Sky Q box keep turning itself off.
@Hayati wrote:
We had this box for a long time. Did update etc but nothing stopped switching off. No matter what you watching it just turn off every 20min to and hour. Need a solution please.
Hi @Hayati
