Discussion topic: problem with your satellite signal
Message posted on 02 Jun 2025 04:49 PM
My Sky TV is coming on and going off every two or three minutes with a message showing:-
This channel is currently affected by a problem with your satellite signal
I have restared , turned off etc etc..
Any hlp Sky
Message posted on 02 Jun 2025 04:53 PM
Re: problem with your satellite signal
Here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Message posted on 02 Jun 2025 04:54 PM
@Dcass08
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 02 Jun 2025 05:49 PM
All fixed now
Thank you
