Discussion topic: Sky Q box keeps jamming
Message posted on 02 Jun 2025 02:29 PM
Main Sky Q box keeps jamming and I need to stick off at mains to reset.
At least once a day.
Total pain
Message posted on 02 Jun 2025 05:27 PM
Re: Sky Q box keeps jamming
Total pain
@GM64 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
