28 Mar 2023 04:28 PM
The new remote for the TV in the back room cannot be paired as when I try and pair it with the Q box in the front room it doesn't pair and just knocks out the remote for that TV. It has been the case when I turn on the TV in the back room it comes up with a black screen that says NO SIGNAL will not connect to sky without the sky remote ON button being pressed. Of course now with the new remote not being paired I cannot get past the black screen to even try and pair it.
28 Mar 2023 04:33 PM
Hi @Theo1690
First try rebooting the Q box in Question .
When the box is up and running
Try completly resetting your new Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
28 Mar 2023 06:22 PM
hi @Theo1690
Please follow the advice from @oldfella
Do also note his warning about line of sight after resetting the remote , as until it is pairred it works in Infrared mode
I do, however, feel I should mention that each remote pairs with the individual SKY Q box so unless yu were just testing the remote I am not too sure why you would try to pair the remote for your mini with the main box
