Discussion topic: my sky Q mini box -connection
This message was authored by: Lottie16
Having problem with my sky mini box connection
Re: my sky Q mini box -connection
Hi @Lottie16
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
