This discussion topic has been answered Discussion topic: Sky q remote seems to have stopped working correctly.
Message posted on 09 Apr 2023 08:54 PM
Message posted on 09 Apr 2023 09:13 PM
Hi @Linzi000
Reboot the Q box again.
Then press and hold 7 & 9 on the remote until it's led flashes four times. Don't try pairing at this point.
This will put the remote into infrared mode and it should work the Q box.
It it does work the box
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
You need to be line of sight as you say to use infrared.
Hi @Linzi000
Message posted on 09 Apr 2023 09:14 PM
Re: Sky q remote seems to have stopped working correctly.
hi @Linzi000
It sounds like maybe you are not able to point the remote at the ir receiver on the box
I have found a page that shows where it is located
https://antiference.co.uk/faq/ir-control-not-working/
Message posted on 09 Apr 2023 09:32 PM
Message posted on 10 Apr 2023 11:08 AM
@oldfella your instructions worked after I left the sky q box unplugged overnight.
Leaving it unplugged for 5 mins or 30mins didn't seem to make a difference. Frustrating, but at least it's now working 😀
