Discussion topic: mute
This message was authored by precinct88 This message was authored by: precinct88
mute
my sky box has no sound. Have tried muting and unmuting box, muting and unmuting tv, switching everything off and on again. Still no sound at all.
Re: mute
hi @precinct88
When you say everything does that include a complete power down (i.e. switch off or remove plug) of your TV.
We often find that a power down of the TV restores sound for people
precinct88
Re: mute
yes, switched off at plugs too. TV has sound but not sky box.
Re: mute
Can I suggest you try toggling the setting in :
Home - Settings - Setup - Audio Visual
Set to a different setting & fully exit
Then go back and change back to the one you normally use.
precinct88
Re: mute
still nothing
Re: mute
@precinct88 wrote:
still nothing
Have you also tried unplugging the HDMI cable at both ends and then plugging back in - I am guessing you probably have but, if not, I suggest you try this also.
BTW Can I just double check that you only use your TV for sound and not a Sound bar or AV amp
Also can you confirm what your usual setting is - is it Normal or Dolby Digital ?
precinct88
Re: mute
confirm only use tv. Good suggestion re cable, will get my son to try when he gets home from work as fiddly to get to. 👍 thanks
Re: mute
I hope that does the trick for you.
After that I admit I am running out of ideas  - often the complete power down does cure such problems
