Discussion topic: Voice Control on Remote says - you are not connected to the internet !
Message posted on 15 Apr 2023 08:10 PM
The sky broadband has been fine & has not stopped. However the VOICE control on the remote, comes up with the screen box - but when you speak, it says you are not connected to the internet.
We have tried resetting everything & oressing the WPS on the Sky Q box - but nothing happens, the orange light just flashes on & off but doesnt go green..
We have tried resestting our Sky Broadband & that doesnt make it work either, but the broadband simply deosnt want to link to the TV box - cant find what to do ...
Message posted on 15 Apr 2023 08:18 PM
Re: Voice Control on Remote says - you are not connected to the internet !
@Chollies60 when you are pressing the wps button on the Q box are you also pressing the wps button on the router
Message posted on 15 Apr 2023 08:22 PM
Hi,
Well i had spent days searching for one - but coudn't find it on the router - i have just thought again & have found it on the side of the router not on the front with everything else - thank you SO much, will give it a try now. !
Message posted on 15 Apr 2023 08:24 PM - last edited: 15 Apr 2023 08:26 PM
@Chollies60 wrote:
Hi,
@Chollies60 yeah the new upright router(the sky broadband hub) has it on the right hand side of it 😄
Message posted on 15 Apr 2023 08:32 PM
Sadly that didnt work ! It looks like it is going to - but doesnt the lights on both router & the SkyQ flash amber & then - nothing !
Look s like a call to SKY ! Joy
Message posted on 15 Apr 2023 09:02 PM
@Chollies60 i know its a pain but i've had occasions where reconnecting mine and its taken 3 or 4 attempts to connect may be worth while trying another couple of times
Message posted on 16 Apr 2023 09:28 AM
Try doing this;
Restart your Sky Q box
- Press standby on your Sky Q remote, then switch off or unplug it at the mains.
- Check there're no lights on the front panel of your Sky Q box and all cables are securely connected.
- Plug in and switch your Sky Q box back on at the mains.
- Wait for the on-screen instructions to disappear then press Home on your Sky Q remote.
Make sure the tv guide is populated on your Sky Q box, may take a few minutes.
Restart your router
- Switch off or unplug your router at the mains socket.
- Check there are no lights on the front of your router.
- Reconnect the power cable or plug in and switch your router back on at the mains. Check the power light has returned.
It can take a few minutes for the internet connection to restart.
Once you've restarted both your box and router, try connecting your box via Wi-Fi again.
- Press Home on your Sky Q remote, then go to Settings followed by Setup.
- Select Network and then select Reset (if Reset is not visible, move to Step 4 below).
- Wait for the Sky Q box to check your network, then select Confirm.
- Once the reset is complete, choose Connect to Sky Broadband WiFi and follow the on-screen instructions to connect your Sky Q box to your Sky hub.
