Discussion topic: Mini sky q box won’t connect tried all resets boot switch on off still won’t work
This message was authored by: Nanny+Nat
Sky q box won't connect been trying last hour done all unplugging resets still won't connect
Re: Mini sky q box won’t connect tried all resets boot switch on off still won’t work
Hi @Nanny+Nat
Reboot the mini as above.
