Discussion topic: mini box
Message posted on 29 May 2025 05:12 PM
mini box
Trying to an engineer to look at mini box that has started to cut out for no reason. When do all the things you are supposed to do then says technical fault or no satellite found really fed up of getting nowhere
Message posted on 29 May 2025 05:58 PM
Re: mini box
Hi @SueQ1960
Have you carried out the following procedure?
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 02 Jun 2025 03:20 PM
Re: mini box
Hello
Thank you for your advice. Yes I tried all those things multiple times and it was either No satellite or technical fault. Have got an engineer coming next week if it keeps going wrong. I think it is the minibox that is not working properly.
Kind regards
