Discussion topic: mini box
Message posted on 05 May 2024 10:06 AM
mini box
mini box does not work saying ‘notconnected to a sky Q box right now’.
advisory steps on box do not work
Message posted on 05 May 2024 10:11 AM
Re: mini box
Hi @GFR79
Reboot the mini as above.
