Discussion topic: mini box will not reconnect
Message posted on 09 Oct 2024 09:59 PM
sky mini box will not reconnect after the power has been off, it will start with the black screen hello etc then shows the blue screen and asks to press home when showing blank screen, then nothing happens left for an hour and nothing tried a few times but it will not do anything past first blue screen.
Message posted on 09 Oct 2024 10:09 PM
Re: mini box will not reconnect
Hi @784856clock
Does the led on the front right of the mini stay amber and not turn green.
If it does press this Amber led (it is the box standby button).
If this turns the box on then
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 10 Oct 2024 02:48 PM
I cant explain it but after trying 10 times last night it connected first try this morning i have not a clue why?
Message posted on 12 Oct 2024 10:51 AM
I would unplug your mini box, SKYBOX and Router. Then plug them back in, in reverse order. I would wait for main box to connect first before plugging in the mini box. Hope this helps, did for me.
