Discussion topic: mini box not working
This message was authored by: menghi
mini box not turning on ,unplugged it three times ,still not working
Re: mini box not working
Hi @menghi
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
