1
This discussion topic has been answered Discussion topic: One of mini boxes not loading as it say max connected alreafy
This message was authored by: Markwed
We have sky q and 3 extra mini boxes. One not working now. Restarted main q box and still mini q box not connecting. Have also reactivated this box.
Re: One of mini boxes not loading as it say max connected alreafy
Hi @Markwed
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Try a Network Reset on the problem mini.
You can also use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Hi @Markwed
