Discussion topic: mini box not keeps disconnecting
This message was authored by leemacca This message was authored by: leemacca
Hi all. recently changed to voneus from sky broadband as they cannot provide fibre in my area. All was going well with connection etc...However my mini box seems to be losing connection multiple times a day.
I have just put in a Tp Link wifi extender in the room. Not sure if this could be causing the issue. Or its as the edge of the range of the new router. No issue with phones, tablets etc.. in the room
Re: mini box not keeps disconnecting
Hi @leemacca
Sky Q minis if using WiFi will not connect to 3rd party WiFi Extenders; they will only connect to Q WiFi (Sky router, Main Q box or Sky Q booster)
Certainly the TPLink could be confusing the Mini connection.
With the Extender switched off First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
If you get the mini connected you could try switching the extender back and/or moving it.
