Discussion topic: mini box keeps buffering
This message was authored by jenniryan This message was authored by: jenniryan
The main sky Q box works perfectly fine but increasingly the mini box is buffering, to a point where its happening almost every night  The mini box is in same room as the internet  router.
Re: mini box keeps buffering
Hi @jenniryan
Are you on Sky Broadband?
jenniryan
Yes.
@jenniryan wrote:
Yes.
Hi @jenniryan
Try a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Sky Q router (assuming this is nearer to the mini than the main Q box)
You will be asked to press the WPS button on the Sky router. (Not on the mini box as the Network reset will start the mini box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
