Discussion topic: mini box keeps buffering
Message posted on 05 Jul 2023 08:30 PM
The main sky Q box works perfectly fine but increasingly the mini box is buffering, to a point where its happening almost every night The mini box is in same room as the internet router.
Message posted on 05 Jul 2023 09:31 PM
Re: mini box keeps buffering
Hi @jenniryan
Are you on Sky Broadband?
Message posted on 09 Jul 2023 03:46 PM
Yes.
Message posted on 09 Jul 2023 03:56 PM
@jenniryan wrote:
Yes.
Hi @jenniryan
Try a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Sky Q router (assuming this is nearer to the mini than the main Q box)
You will be asked to press the WPS button on the Sky router. (Not on the mini box as the Network reset will start the mini box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
