3
This discussion topic has been answered Discussion topic: lost the sky q interface
This message was authored by: mith75
as of yesterday i have lost all sky tv channels and the sky interface so nothing comes up when home button pushed.  changed batteries on remote and reset off/on a number of times.  Nothing helps.  cannot factory reset as cannot get into sky interface settings ?
This message was authored by: Chodley Answer
Re: lost the sky q interface
Done a remote reset ? Hold down 7&9. After the remote flashes, hold down 1&3 to also reset the TV infrared controls.
Hi @mith75 Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Avatar for mith75
thank you
the 7 and 9 worked
