2
This discussion topic has been answered Discussion topic: itvBe
This message was authored by: leewright76
itvBe
Do you need a certain package to be able to download iveBe programmes?
It will let me set up record but won't let me download?
I don't have HD, so changed to download in SD and it still won't let me.
This message was authored by: nigea99 Answer
Re: itvBe
hi @leewright76
Did you just try to download the SD version or change your default download preference :to SD
Main Menu -> Settings -> Setup -> Preferences ?
Re: itvBe
hi @leewright76
Avatar for leewright76
Re: itvBe
@nigea99 I had only tried to download the SD version. But have just changed preferences to SD and now it works ! Thank you!!
