Discussion topic: internet conection to skyQ box
Message posted on 02 Sep 2023 07:18 PM
hello since becoming a skyQ customer after having sky+ for a number of years im having a constant problem with the connection to the skyQbox from my internet with recordings and apps constatky saying no connection or limited services available i never had a problem until i changed to skyQ internet is an absolute nightmare please help as dont understand what im paying for????
Message posted on 03 Sep 2023 09:08 AM
Re: internet conection to skyQ box
Hi @konee4112 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?.
Message posted on 14 Dec 2023 11:04 PM
constantly having to re set Sky Q box and router ! sitting for hours finger on WPS button then still NO CONNECTION ! Why does this keep happening ??? then it says unsuccessful connection try again or you may need a Sky Q Booster !!! had Sky for years never needed a booster ! Just a blooming Joke this is now !
Message posted on 15 Dec 2023 09:14 AM - last edited: 15 Dec 2023 09:14 AM
@skymymalamute wrote:constantly having to re set Sky Q box and router ! sitting for hours finger on WPS button then still NO CONNECTION ! Why does this keep happening ??? then it says unsuccessful connection try again or you may need a Sky Q Booster !!! had Sky for years never needed a booster ! Just a blooming Joke this is now !
Try the steps I put in post 7 of this thread and also have a look at post 8
https://helpforum.sky.com/t5/Sky-Q/Sky-q-box-not-linking-with-Wi-Fi/m-p/4504698#M618552
Did Sky+HD have wifi? (Fwiw I think the wifi on Q is bad)
