Discussion topic: hill
Message posted on 21 Nov 2023 08:10 PM
hill
our sky mini box has turned it self off and wont come back on ? ive tried turning it of the mains for over an hour still no joy ive tried re setting no joy i need to talk to someone but as per usual no way to get in touch . realy bad servise
Message posted on 21 Nov 2023 08:13 PM
Re: hill
Hi @martin71
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
