Discussion topic: On all of our mimi box’s when you turn on and turn over the picture freezes and staggers several tim
Message posted on 21 Nov 2023 04:52 PM
Hi on all of our mini box's when you turn on and when you change channels the screen takes time to turn on and freezes several times this is getting worst each week
Message posted on 21 Nov 2023 04:57 PM
Re: On all of our mimi box’s when you turn on and turn over the picture freezes and staggers several
@pipcooper Have you tried rebooting your main Q box ie
then
reboot each mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Nov 2023 06:46 PM
Yes
Ive had the skyQ box off for several hours and each mini box has been re booted with no difference
Message posted on 21 Nov 2023 07:01 PM
@pipcooper wrote:
Yes
Hi @pipcooper
Try a Network Reset on the minis. Start with the one nearest to the Main Q box (or if you are Sky Broadband the nearest one to to the Sky router if it is nearer than the main Q box)
If you get the mini connected satisfactory then carry out the Network reset on the next nearest mini. When asked you can press on the WPS on the nearest Q device (the previously connected min or the main Q box or a Sky Q router. Whichever is nearest)
Message posted on 21 Nov 2023 07:22 PM
REally annoying that having taken a new router recentky I now need a booster to resolve issues foreced on me by Sky
not really enviromentally friendly having to connect another device - Sky?
Message posted on 21 Nov 2023 07:50 PM
Hi @pipcooper
What happens when you carry out the Network reset on the minis?
Who is your broadband supplier ?
Message posted on 21 Nov 2023 08:16 PM
one closet to router was better other two (upstairs) no different
sky broadband
