7
This discussion topic has been answered Discussion topic: discovery plus stuck on privacy notice
This message was authored by: dam01
I'm trying to load Discovery Plus from the apps menu for the first time. I accept the privacy notice, and a spinning circle appears; it just sticks to the page with the privacy notice.... The circle continually spins.
All I can do is hit home and exit.
What can I do to resolve?
This message was authored by: wgbirne Answer
Re: discovery plus stuck on privacy notice
Had the same problem for the last couple of days and finally found the solution:
I have a pihole running and it blocked a request from the sky q receiver to cdn.cookielaw.org. After whitelisting this request the Discovery+ app is no longer stuck on the privacy notice.
This message was authored by: BoydieUK
I have the same issue after activating discovery+, just started my sky subscription too.
@dam01 @BoydieUK you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for dam01
Thanks., but this did not fix the issue.
Avatar for dam01
Thank you.
That was it. I run 'nextdns' which does the same thing. I whitelisted the domain and it worked!
@wgbirne
did you have to leave it whitelisted after ?
This message was authored by: SMcGill1969
Thank you - it's  always easier when someone else has done the leg work... 🤣
They obviously don't just port the software 'as-is' because Pi-hole was not affecting Discovery+ on any other devices on my network (AppleTV / FireTV / Phones etc).
This message was authored by: IanR2
I also had to whitelist "js-agent.newrelic.com".
