This discussion topic has been answered Discussion topic: discovery plus stuck on privacy notice
Message posted on ‎23 Jul 2024 10:16 PM
I'm trying to load Discovery Plus from the apps menu for the first time. I accept the privacy notice, and a spinning circle appears; it just sticks to the page with the privacy notice.... The circle continually spins.
All I can do is hit home and exit.
What can I do to resolve?
Message posted on ‎27 Jul 2024 08:32 AM
Had the same problem for the last couple of days and finally found the solution:
I have a pihole running and it blocked a request from the sky q receiver to cdn.cookielaw.org. After whitelisting this request the Discovery+ app is no longer stuck on the privacy notice.
Message posted on ‎24 Jul 2024 05:17 PM
Re: discovery plus stuck on privacy notice
I have the same issue after activating discovery+, just started my sky subscription too.
Message posted on ‎24 Jul 2024 05:37 PM
@dam01 @BoydieUK you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
Message posted on ‎24 Jul 2024 07:36 PM
Thanks., but this did not fix the issue.
Message posted on ‎27 Jul 2024 09:35 AM
Thank you.
That was it. I run 'nextdns' which does the same thing. I whitelisted the domain and it worked!
did you have to leave it whitelisted after ?
Message posted on ‎24 Mar 2025 07:58 PM
Thank you - it's always easier when someone else has done the leg work... 🤣
They obviously don't just port the software 'as-is' because Pi-hole was not affecting Discovery+ on any other devices on my network (AppleTV / FireTV / Phones etc).
